dikh
УчастникЕсть хорошяя новость — комп код сгенерировался, но есть и плохая — все перестало работать:
2025-10-29 23:05:53 [DESKTOP-Q8B2AKJ][DESKTOP-Q8B2AKJ$][ACT] Receive the configuration database
2025-10-29 23:05:55 [DESKTOP-Q8B2AKJ][DESKTOP-Q8B2AKJ$][ERR] Resolver could not find assembly ‘ScadaWebCommon.Subset, Version=6.2.2.0, Culture=neutral, PublicKeyToken=null’
requested by ‘PlgChartPro.View, Version=6.1.1.0, Culture=neutral, PublicKeyToken=null’
2025-10-29 23:05:55 [DESKTOP-Q8B2AKJ][DESKTOP-Q8B2AKJ$][ERR] Web host failed to start:
System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types.
Could not load file or assembly ‘ScadaWebCommon.Subset, Version=6.2.2.0, Culture=neutral, PublicKeyToken=null’. The system cannot find the file specified.
at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
at Microsoft.AspNetCore.Mvc.Controllers.ControllerFeatureProvider.PopulateFeature(IEnumerable`1 parts, ControllerFeature feature)
at Microsoft.AspNetCore.Mvc.ApplicationParts.ApplicationPartManager.PopulateFeature[TFeature](TFeature feature)
at Microsoft.AspNetCore.Mvc.ApplicationModels.ControllerActionDescriptorProvider.GetControllerTypes()
at Microsoft.AspNetCore.Mvc.ApplicationModels.ControllerActionDescriptorProvider.GetDescriptors()
at Microsoft.AspNetCore.Mvc.ApplicationModels.ControllerActionDescriptorProvider.OnProvidersExecuting(ActionDescriptorProviderContext context)
at Microsoft.AspNetCore.Mvc.Infrastructure.DefaultActionDescriptorCollectionProvider.UpdateCollection()
at Microsoft.AspNetCore.Mvc.Infrastructure.DefaultActionDescriptorCollectionProvider.Initialize()
at Microsoft.AspNetCore.Mvc.Infrastructure.DefaultActionDescriptorCollectionProvider.GetChangeToken()
at Microsoft.Extensions.Primitives.ChangeToken.ChangeTokenRegistration1..ctor(Func1 changeTokenProducer, Action`1 changeTokenConsumer, TState state)
at Microsoft.Extensions.Primitives.ChangeToken.OnChange(Func`1 changeTokenProducer, Action changeTokenConsumer)
at Microsoft.AspNetCore.Mvc.Routing.ActionEndpointDataSourceBase.Subscribe()
at Microsoft.AspNetCore.Builder.RazorPagesEndpointRouteBuilderExtensions.GetOrCreateDataSource(IEndpointRouteBuilder endpoints)
at Microsoft.AspNetCore.Builder.RazorPagesEndpointRouteBuilderExtensions.MapRazorPages(IEndpointRouteBuilder endpoints)
at Scada.Web.Program.ConfigureApplication(WebApplication app)
at Scada.Web.Program.RunWebHost(String[] args)
System.IO.FileNotFoundException: Could not load file or assembly ‘ScadaWebCommon.Subset, Version=6.2.2.0, Culture=neutral, PublicKeyToken=null’. The system cannot find the file specified.
File name: ‘ScadaWebCommon.Subset, Version=6.2.2.0, Culture=neutral, PublicKeyToken=null’
2025-10-29 23:05:57 [DESKTOP-Q8B2AKJ][DESKTOP-Q8B2AKJ$][ACT] The configuration database has been received successfully
2025-10-29 23:05:57 [DESKTOP-Q8B2AKJ][DESKTOP-Q8B2AKJ$][INF] The application is ready for operating
2025-10-29 23:05:57 [DESKTOP-Q8B2AKJ][DESKTOP-Q8B2AKJ$][ACT] Webstation is stopped
———————————————————————————dikh
УчастникСпасибо!
dikh
Участникспасибо, опробую!
dikh
УчастникТег статутс почему то не работает — у меня устройства онлайн, а он показывается 0.
dikh
УчастникА нету видео с примерами использования этого плагина?
dikh
Участникa80808 — нет, тут именно в удобстве что на одном графике происзодят взаимосвязанные события.
Mikhail — а их можно встроить на страницу менмосхемы? https://rapidscada.ru/download-all-files/download-component-for-charting/ — и как будут выглядить графики, если улсовно три графика будут между 1 и 0?dikh
Участникспасибо, попробую.
dikh
УчастникСпасибо,но понятнеее не стало) куда его добавлять — в карту тегов? Или в каналы? И в какой форме? Нету ли скриншота с примером?
dikh
УчастникНе понял как работают ссылки — допустим у меня есть два представления по адресам
http://localhost:10008/View/1
http://localhost:10008/View/2
Первое называется MainDiagram.sch, второе Diagram.sch. Что нужно указывать в адресе для корректного перехода?dikh
УчастникДобрый день.
Чтото читаю, и не понимаю — у меня есть линия ModBus RTU, там допустим 10 устрйоств с номерами 1…10. Могу я как нибудь считывать статус устрйоства — онлайн или не онлайн? Мне нужно выводить карсную иконку, чтобы бежали разбирались почему связь пропала) Ну или большую надпись «ОФФЛАЙН»)dikh
Участник@manjey73, спасибо.
А если мне в зависимости от нескольких условий нужно менять статус канала? Т.е. использовать if?
Т.е. допустим:
если канал 2 = 0 тогда канал 1 = 0
если канал 2 <> 0, а канал 3 от 1 до 5 тогда канал 1 = 1
если канал 2 <> 0, а канал 3 от 4 до 5 и канал 4 = 10 тогда канал 1 = 3
Нашел, нужно делать функции.dikh
УчастникДопустим у меня по каналу № 1234 происходит считываение регистра, из которого мне нужно вычесть биты, значит я создаю 3 канала и формулы быдут выглядеть так:
Канал №1235 — GetBit(Val(1234),0) — считать 0ой бит из канала 1234
Канал №1236 — GetBit(Val(1234),5) — считать 5ый бит из канала 1234
Канал №1237 — GetBit(Val(1234),10) — считать 10ый бит из канала 1234
Я прав?-
Ответ изменён 1 год, 1 месяц назад пользователем
dikh.
dikh
УчастникА как такое же сделать в IIS? сделал bindings, но чтото не работает(
dikh
УчастникДа я то откуда знаю чем аргументировано) у меня может быть доступ по ассистенту.рф (это как энидеск) к тому серваку.
dikh
УчастникТакого (10002) 146% не дадут. 22 есть (как раз через него доступ к консоли и заливка файлов). Там еще монитора не будет (работа только через консоль/файловый менеджер SSH).
