Некорректная отправка пакетов
Стартовая страница › Форумы › Вопросы без категории › Некорректная отправка пакетов
  • #4306
    Pavel
    Добрый день. Настроил GSM TELEOFIS RX108-R2 на отправку пакетов через Сим-карту посредством Tcp/ip соединения. Проблема вот в чем:
    [15:45:35] 539192963 # IMEI: 044245656
    [15:45:35] 539192964 # AUTH REPLY: яю‘˜»Ј]MS
    [15:45:36] 539192964 # Sending data to socket #1 (data): 18 bytes
    [15:45:36] 539192965 # Authorization complete
    [15:46:37] 539193025 # Trying to open a socket #1 (data)
    [15:46:47] 539193035 # Socket 1 connected to *******************************************:*****
    [15:46:47] 539193036 # Start authorization on socket #1 (data)
    [15:46:50] 539193038 # Data received from socket #1 (data): 28 bytes
    [15:46:50] 539193039 # IMEI RAW:
    [15:46:50] 355094044245656
    [15:46:50] OK
    [15:46:51] 539193039 # IMEI: 044245656
    [15:46:52] 539193040 # AUTH REPLY: яю‘˜»Ј]MS
    [15:46:52] 539193041 # Sending data to socket #1 (data): 18 bytes
    [15:46:53] 539193041 # Authorization complete
    [15:48:15] 539193124 # Trying to open a socket #1 (data)
    [15:48:22] 539193131 # Socket 1 connected to *******************************************:*****
    [15:48:22] 539193131 # Start authorization on socket #1 (data)
    [15:48:25] 539193133 # Data received from socket #1 (data): 28 bytes
    [15:48:26] 539193134 # IMEI RAW:
    [15:48:26] 355094044245656
    [15:48:26] OK
    [15:48:26] 539193135 # IMEI: 044245656
    [15:48:27] 539193135 # AUTH REPLY: яю‘˜»Ј]MS
    [15:48:27] 539193136 # Sending data to socket #1 (data): 18 bytes
    [15:48:28] 539193136 # Authorization complete
    [15:49:21] 539193190 # Trying to open a socket #1 (data)
    [15:49:55] 539193223 # Socket 1 connected to *******************************************:*****
    [15:49:55] 539193224 # Start authorization on socket #1 (data)
    [15:49:58] 539193226 # Data received from socket #1 (data): 13 bytes
    [15:49:59] 539193227 # IMEI RAW:
    [15:49:59] 355094044245656
    [15:49:59] OK
    Т.е. каждое подключение происходит примерно через 40 сек. что в свою очередь неудобно. Подскажите пожалуйста, какой исправить данную проблему. Спасибо.
    #4307
    Kazam
    А что вы хотите получить?
    увеличить интервал, или получить постоянную связь?
    модем подключается к белому ip ? есть ли промежуточный роутер?
    #4308
    Pavel
    Всем спасибо, разобрался.
