Vasily777
УчастникПоставил 5_5_2 с моно по ссылке. Перекинул тестовый рабочий проект с 7-ки — он точно работает (240 каналов на одном ком порте линия 11).
/opt/scada/ScadaComm/Log/ScadaCommSvc.log
2018-06-07 12:20:46 <raspberrypi><root><ACT> ScadaCommService 5.1.0.3 is started
2018-06-07 12:20:47 <raspberrypi><root><ACT> Load device library: KpModbus.dll
2018-06-07 12:20:48 <raspberrypi><root><EXC> Error creating communication line 11: Error getting device logic type from the library KpModbus.dll: Could not load file or assembly ‘ScadaCommCommon, Version=5.1.0.2, Culture=neutral, PublicKeyToken=null’ or one of its dependencies.
2018-06-07 12:20:48 <raspberrypi><root><ERR> No active communication lines
2018-06-07 12:20:48 <raspberrypi><root><ERR> Normal program execution is impossible./opt/scada/ScadaServer/Log/
2018-06-07 12:20:46 <raspberrypi><root><ACT> ScadaServerService 5.1.0.3 is started
2018-06-07 12:20:47 <raspberrypi><root><ACT> Check the existence of the data directories is completed successfully
2018-06-07 12:20:47 <raspberrypi><root><ACT> Check the existence of the configuration database files is completed successfully
2018-06-07 12:20:49 <raspberrypi><root><ACT> Input channels are read from the configuration database. Active channel count: 240
2018-06-07 12:20:49 <raspberrypi><root><ACT> Ouput channels are read from the configuration database
2018-06-07 12:20:49 <raspberrypi><root><ACT> Users are read from the configuration database
2018-06-07 12:20:49 <raspberrypi><root><ACT> Formulas are read from the configuration database
2018-06-07 12:20:53 <raspberrypi><root><ACT> The formulas source code has been compiled
2018-06-07 12:20:54 <raspberrypi><root><ACT> Connection listener is started
2018-06-07 12:20:54 <raspberrypi><root><ACT> Start server
2018-06-07 12:20:54 <raspberrypi><root><ACT> Current data are not loadedЛиния 11 соответственно не работает
Ставил именно 5_5_2 и на винде и распберри.
Куда копать?
Для переустановки 5_5_2 на 5_5_1 можно как то обойтись удалением 5_5_2 и установкой 5_5_1 без полной установки распбиан + моно+апаш?Vasily777
УчастникСпасибо за информацию. На выходных попробую поставить. Если интересны результаты, отпишусь
Vasily777
УчастникПо вашему опыту, о каких сроках идет речь?
Ответ изменён 8 лет, 5 месяцев назад пользователем
Vasily777.
Vasily777
УчастникVasily777
Участникwww-data. Сразу после перезагрузки (RES ~55000 %MEM ~6) Через 1ч40 мин (RES ~252000 %MEM ~26) и продолжает расти.
Vasily777
УчастникПри открытой таблице в браузере распберрри (больше ничего не открывал) через 3-4 часа работы система виснет (проверял дважды).
В окне терминала, команда top значение KiB Mem used постепенно растет (начальное около 200 000, конечное > 600000).
На последней версии mono такое не наблюдается?Vasily777
Участникpi@raspberrypi:~ $ mono —version
Mono JIT compiler version 4.6.2 (Debian 4.6.2.7+dfsg-1)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. http://www.mono-project.com
TLS: normal
SIGSEGV: normal
Notifications: epoll
Architecture: armel,vfp+hard
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgenVasily777
УчастникУвеличил количество устройств (КП) до 120 (240 каналов) интервал опроса 30 секунд, 1 линия rs485. 12 часов работы, пока все стабильно, данные по всем каналам есть, цифры в шапке (top) примерно одни и те же. Количество свободной памяти по сравнению с 30-ю уменьшилось примерно в два раза. Ошибки по обновлению данных на странице (красный цвет) не повляются. www-data 1 процесс + периодически появляются исчезают 1-2шт www-data (apache2)
Vasily777
УчастникЗакинул тестовый проект на Raspberry (apache), опрос 30-ти датчиков (по 2 modbus-регистра в каждом) (имитирую 1-м датчико м) по rs485 (modbus-rtu) через преобразователь с интервалом 20 сек. Работает, но изредка выскакивают и затем пропадают Error updating current data, Error updating current events. Но в целом все работает по 10-12 часов (больше пока не получается по организационным причинам).
Vasily777
УчастникНе понял, в каком случае поставится старая, а в каком новая?
Если делать по ссылке (я по ней и делаю), установится новая версия mono?
Как устанавливается старая версия mono?
Извините за непонятливость, с распберри и линуксом вторую неделю. Непривычно, как в DOS-е c его командной строкой.-
Ответ изменён 8 лет, 6 месяцев назад пользователем
Vasily777.
Vasily777
УчастникТ.е если Mono ставить обычным способом, то из-за блокировки может установиться старая версия?
Ставил по инструкции отсюда.
Не в курсе был насчет блокировки.
Т.е если правильно вас понял, ставить mono нужно отсюда, но из под VPN. Вероятно, лучше вообще все устанавливать из под VPN, из-за долбаного роскомнадзора.
Еще вопрос по установке mono:
В инструкции по установке:5. Add the Mono repository to your system.
Open http://www.mono-project.com/download/#download-lin and follow the instructions of paragraph 1.Example for Debian:
sudo apt-key adv —keyserver hkp://keyserver.ubuntu.com:80 —recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
echo «deb http://download.mono-project.com/repo/debian stretch main» | sudo tee /etc/apt/sources.list.d/mono-official.list
sudo apt-get updateПо ссылке для raspbian для mono, после добавления репозиториев по параграфу 1 (в инструкции):
sudo apt install apt-transport-https dirmngr
echo «deb https://download.mono-project.com/repo/debian stable-raspbianstretch main» | sudo tee /etc/apt/sources.list.d/mono-official-stable.list
sudo apt updateПунктом 2 идет сама установка:
Install Mono
sudo apt install mono-develЕе нужно в этом пункте делать или нет?
Vasily777
УчастникЕсли зайти http://192.168.0.71:8084/scada/ с Распберри и по локалке то работают оба подключения.
Vasily777
УчастникПохоже не из-за блокировки
Под ВПН Раздавал с телефона с влюченным Турбо-ВПН через роутер подключенным к телефону
pi@raspberrypi:~ $ sudo apt update
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Err:3 https://download.mono-project.com/repo/debian stable-raspbianstretch InRelease
Connection timed out after 120000 milliseconds
Reading package lists… Done
Building dependency tree
Reading state information… Done
25 packages can be upgraded. Run ‘apt list —upgradable’ to see them.
W: Failed to fetch https://download.mono-project.com/repo/debian/dists/stable-raspbianstretch/InRelease Connection timed out after 120000 milliseconds
W: Some index files failed to download. They have been ignored, or old ones used instead.
На текущий момент у Вас работает Rapid SCADA на Raspberry?
Работает следующим образом.
После перезагрузки распберри, если зайти первоначально с распберри http://127.0.0.1:8084/scada/ , то при заходе по локальной сети, пишет красным ошибки при обновлении данных.
И наоборот, если сразу после перезагрузки, зайти по локалке то работает. Но теперь возникают такие же ошибки при просмотре в окне браузера распберри
Т.е что первое (распберри или сеть) подключится то и работает, другое нет.Vasily777
TLS: normal
SIGSEGV: normal
Disabled: none
Misc: softdebug
GC: sgen -
