defelot
  • в ответ на: Гибкий отчет и типы ячеек Excel #44865
    defelot
    Версия плагина 6.1.2.0. Пример готового отчета на яндекс диске:
    https://disk.yandex.ru/i/IDTtefuI78nzZg
    в ответ на: Гибкий отчет и типы ячеек Excel #44842
    defelot
    <?xml version=»1.0″ encoding=»utf-8″ ?>
    <ElasticReport>
    <!— Input form options —>
    <InputOptions>
    <!— User can select report period —>
    <SelectPeriod>true</SelectPeriod>
    <!— User can select archive —>
    <SelectArchive>false</SelectArchive>
    <!— User can select channels —>
    <SelectChannels>false</SelectChannels>
    <!— User can select output format —>
    <SelectFormat>false</SelectFormat>
    <!— Defines how the period is entered. Possible values: SingleDate, SingleMonth, DatePeriod, DateTimePeriod, MonthPeriod —>
    <PeriodControl>DatePeriod</PeriodControl>
    <!— Maximum report period in days —>
    <MaxPeriod>31</MaxPeriod>
    <!— Default archive code —>
    <DefaultArchive>Hour</DefaultArchive>
    <!— Default output format: Pdf, Xlsx, Html —>
    <DefaultFormat>Xlsx</DefaultFormat>
    </InputOptions>
    <!— Output options. Page format and orientation only work for PDF —>
    <OutputOptions>
    <!— Page format: A0, A1, A2, A3, A4, A5, A6, B5, Letter, Legal, Ledger or P11x17 —>
    <PageFormat>A4</PageFormat>
    <!— Page orientation: Portrait or Landscape —>
    <Orientation>Landscape</Orientation>
    <!— Specifies custom report styles —>
    <StyleSheet></StyleSheet>
    </OutputOptions>
    Report document consists of sections. Section is a separate block of displayed data.
    Section contains elements such as a table, columns, rows, and cells.
    Section working period is based on the specified report period and shifted according to the section data options.
    Element attributes are inherited from an element to its children and applied to suitable elements.
    The following element attributes are supported:
    * cnlNum — channel number,
    * cnlIdx — channel index if channels are specified as input parameters,
    * calcType — calculation type,
    * calcSum — whether to calculate a sum of a column or row,
    * calcAvg — whether to calculate an average of a column or row,
    * calcMin — whether to calculate a minimum value of a column or row,
    * calcMax — whether to calculate a maximum value of a column or row,
    * colStyle — column style,
    * rowStyle — row style,
    * cellStyle — cell style.
    Table attributes:
    * border — whether to display table border.
    The possible values of the calcType attribute:
    * Val — the value of the bound channel at the processed timestamp,
    * FirstVal — the value at the first timestamp of the working period,
    * LastVal — the value at the last timestamp of the working period,
    * Diff — the difference between the values at the processed and previous timestamps,
    * DiffNext — the difference between the values at the next and processed timestamps,
    * Const — the constant value to insert in the corresponding cell,
    * Formula — the formula to insert in the corresponding cell, supported only by Excel.
    Style names follow the rules:
    Column style name must be in the form «col-*».
    Row style name must be in the form «row-*».
    Cell style name must be in the form «cell-*».
    Variables can be used inside an element name and inside a constant value.
    The following variables are supported:
    {CnlNum} — channel number,
    {CnlName} — channel name.
    <Document>
    <DocumentOptions>
    <!— Heading of the report —>
    <Heading>Отчет УКЗ-1</Heading>
    <!— Show or hide heading —>
    <HeadingVisible>true</HeadingVisible>
    <!— Set text color depending on channel status —>
    <UseStatusColor>true</UseStatusColor>
    </DocumentOptions>
    Section of TimeData type.
    Supported calculation types: Val, Diff, DiffNext, Const, Formula.
    <Section type=»TimeData»>
    <SectionOptions>
    <!— Unique section ID. Use Latin characters without spaces —>
    <ID>UKZ1</ID>
    <!— Subheading of the section —>
    <Subheading>Параметры УКЗ-1</Subheading>
    <!— Show or hide subheading —>
    <SubheadingVisible>true</SubheadingVisible>
    <!— Start the section on a new page —>
    <PrependPageBreak>false</PrependPageBreak>
    </SectionOptions>
    <DataOptions>
    <!— Prepend additional time before the report start time —>
    <PrependTime>0:00:00</PrependTime>
    <!— Append additional time after the report end time —>
    <AppendTime>0:00:00</AppendTime>
    <!— Skip the first timestamp from output —>
    <SkipFirst>false</SkipFirst>
    <!— Skip the last timestamp from output —>
    <SkipLast>false</SkipLast>
    <!— Defines how timestamps are enumerated. Possible values: All, Step, Hour, Day, Month, Exact, BeginEnd —>
    <TimeDetailing>Hour</TimeDetailing>
    <!— Time step —>
    <TimeStep>0:10:00</TimeStep>
    <!— Times of day separated by commas —>
    <ExactTimes>0:00, 12:00</ExactTimes>
    <!— Defines how the date and time column is displayed —>
    <ShowDatesOnly>false</ShowDatesOnly>
    </DataOptions>
    <Table border=»true»>
    <ColumnGroup name=»ЭХЗ»>
    <Column name=»EΣизм» cnlNum=»1043″ calcType=»Val» />
    <Column name=»Eпол.изм» cnlNum=»1044″ calcType=»Val» colStyle=»col-sm» />
    <Column name=»Eтр-ВЭ» cnlNum=»1045″ calcType=»Val» colStyle=»col-sm» />
    <Column name=»E~изм» cnlNum=»1049″ calcType=»Val» colStyle=»col-sm» />
    <Column name=»E~ВЭ» cnlNum=»1050″ calcType=»Val» colStyle=»col-sm» />
    <Column name=»Iпол.ВЭ» cnlNum=»1051″ calcType=»Val» colStyle=»col-sm» />
    </ColumnGroup>
    <ColumnGroup name=»СКЗ»>
    <Column name=»Uвых.СКЗ» cnlNum=»1111″ calcType=»Val» colStyle=»col-sm» />
    <Column name=»Iвых.СКЗ» cnlNum=»1112″ calcType=»Val» colStyle=»col-sm» />
    </ColumnGroup>
    </Table>
    </Section>
